I am looking job for embedded engineer What should be the answer to the question - How much do you rate yourself in C programming on the scale of 10. This is a question that is asked in interviews everywhere.
My problem is that if I give a point between 1-6, then I will be considered very flame If I give myself points between 6-10, then I have to prove this, I am very good I rated myself 7 points in Interview
Interviewer asked me a question Write a program to Check whether a given point lies inside a triangle or not. I said very politely that sorry sir, I do not know the logic of this, so I cannot write the program. again interviewer asked a question Write Program for Fibonacci numbers
I got a little nervous because I didn't even know the logic then how can write program. I said Sir, if I know logic, then I can write the program I know the logic for embedded devices so I can write program for embedded device
He said that you have rated yourself 7 points, then you should able to write program.
Now I get nervous because I am not so good at maths I don't even have to write programs for no-tech problems. I understood communication protocol like uart i2c spi etc I can write programs only for embedded devices because I have spent my time on it.
What should be the answer to the question - How much do you rate yourself in C programming on the scale of 10?
