I recently built out the circuit depicted in the schematic attached. I inadvertently purchased and soldered in an LED that has a forward voltage rating of 12V. While I was certainly not paying attention during many steps of that process, I can't say I would have ended up with the right LED for the circuit had I noticed the 12V rating and immediately known that wasn't correct. Basically I am just trying to control this solid state relay via a digital output and would like to have the LED to indicate that the relay is active. I am limited to a 5VDC relay input and 3.3vdc signal input. Any guidance would be greatly appreciated.
