The cap;
222M = 222 (2200pF) tolerance M (5% ?)
KX250~ = 250v AC
X1Y1 (complies with X1 and Y1 spec for cap safety)
It's very hard to blowup a cap of that type, and when they do blow they almost always short out badly (and may be cracked open).
The most common cause of failure in that type of SMPS would be an open circuit LV supply resistor R808, 830, both 10k) or a failed electro in the LV supply C814 47uF. Replace that cap and lift one leg of each resistor and measure them.
Also check the 390k resistors in the Vsense line R812,3,4,5, again lift one leg and measure them.
And the other 390k HV resistors 806,7,3,5.
And what's the voltage from IC pin8 to pin6?
KX250~ = 250v AC
