This looks like a low power stereo amplifier. The big tube over to the right is a rectifier for the power supply. The small tubes at the front are a pre-amplifier stage (probably either 12AX7A or 12AU7A twin triodes). The taller tubes at the back are likely the output stage and probably drive the output transformers in a push-pull fashion.i have seen this glass tubes many time, pls tell name of it in this circuit...?
Op-amps are the basic building block of modern linear electronics design. They can be used in literally thousands of different ways. Oscillators, servo amplifiers, integrators, differentiators, comparators, switches, summing, mixing, etc... Without a schematic of the UPS, it would be difficult to tell you to what specific use they were put.ok, what the use of so many op-amp Ic??
Yeah right, I started as newbie but not as bad as him. I used every reference book I have, read it and try to understand it. If I don't really understand it then I ask other's opinion. What I'm saying is atleast give some effort. let me ask you too, you started as newbie as well but do you see yourself with him when you are a newbie?Hello,
@newbies_hobbyist
There are NO stupid questions.
There can be stupid replies.
How did you start yourself?
Bertus
by Jake Hertz
by Robert Keim
by Jake Hertz
by Duane Benson
