What is this component? I recieved it for free from China but I can’t identify it.
martonbaksa
Joined Apr 16, 2018
8
Hi all,
I recieved a package from China and inside the box there was “a free gift of 250grams of random electronics”. I recognized most of the things inside as they were resistors, capacitors etc, but this one unmarked component stumped me. It didn’t read any capacitance, the resistance fluctuated from 3m ohms to 111k ohms. In general this left me stumped. Here’s a photo of the component:
https://ibb.co/ki0zzT
Thanks for your help,
martonbaksa
Ps. The scale is in cm. if that helps.
bertus
Joined Apr 5, 2008
22,276
I cropped the parts from the huge picture:
I think they could be IR leds, like the ones used for remote control.
Bertus
bertus
Joined Apr 5, 2008
22,276
It depends on the current and voltage range of the diode test of your meter.
An IR led should have a forward voltage of about 1.1-1.4 volts.
Bertus
martonbaksa
Joined Apr 16, 2018
8
Bertus
Ok. Thanks for the help. I have no way to test a diode with that forward voltage as I have no receiver for the led. When I have such a means of testing I will confirm what these components actually are. Thanks everyone for your help.
Sincerely,
martonbaksa
AlbertHall
Joined Jun 4, 2014
12,346
If you have a 9V battery and a 1kΩ resistor then connect them in series with a 'mystery' device and measure the voltage across the device. Try this with the device both ways round. If you get 9V one way and 1.5V to 4V the other way then it is likely they IR LEDs or just possibly phototransistors.
30,801
... and view the object with a digital camera. If it is IR emitter it will be visible with a digital camera.
martonbaksa
Joined Apr 16, 2018
8
Oh yeah. I forgot about the fact that digital cameras can see the IR Spectrum with a digital camera. I’m going to get around to this either later today or tomorrow and see the results. Thanks all for your help.
martonbaksa
