What is the name and utility of this LTspice component?
34,468
It is a voltage source, the same as V1 in you schematic but with a different symbol.
It is shown as a single cell battery symbol, to indicate that it usually represents a DC voltage source, but it can be specified for any type of voltage output, as can V1.
mike__MecE
Joined Feb 20, 2022
69
hi mike,
It is a Cell, set V to suit the required voltage.
E
Thanks, that makes sense. I looked through all of the symbols under sym but neglected to review the nested folders like misc.
So this would be a battery charging circuit. The circuit is actually from the VISHAY Simulation Notes for SPICE Modelling the PTCTL, PTCCL, and PTCEL tangent to the topic you were helping me with previously. I am going to recreate all the circuits in the app notes for practice.
mike__MecE
Joined Feb 20, 2022
69
Thank you. I believe this would model a battery charging circuit then? I can't imagine any other reason for the second voltage. source.
ericgibbs
Joined Jan 29, 2010
18,872
hi mike,
As the basic Cell has no internal resistance and the V=0 it is often used as a convenient way of measuring the current through a circuit without interfering with the circuit's operation.
E
eetech00
Joined Jun 8, 2013
3,961
No. it is not a charging circuit.
It is a circuit that demonstrates the behavior of current vs temperature thu a PTC (Positive Temperature Coefficient - Thermistor) type device.
V3 is a voltage source but can be used as a "Current Meter" if the value is set to 0 (zero). The current can then be displayed in the waveform viewer by mousing over V3 then clicking V3.
ericgibbs
Joined Jan 29, 2010
18,872
hi @eetech00
I have checked and cannot find any record showing an Edit or Deletion of the TS threads or posts.
All editing or changes are logged on the site.
I would like to see any evidence of the alleged editing, and will look into it further.
Moderation.
eetech00
Joined Jun 8, 2013
3,961
hi @eetech00
Moderation.
Nevertheless, my reply in post #8 is completely relevant (and accurate to the title of the thread) to the response from the TS.
ericgibbs
Joined Jan 29, 2010
18,872
hi Mike,
I am unsure why they have done that in this particular circuit.
I only use that method when working with OPA amps, so that the presence of the Vsrc does not affect the measurements I am making between two points in the circuit.
E
30,077
Hi Eric, may I ask why that would be necessary/different from simply measuring the current through the thermistor U1?
It's not necessarily necessary, just a common technique that many people use as standard practice. One utility that it has is of decoupling the current-sensing function from the circuit topology, allowing you to make arbitrary changes to the circuit and just move your current-sensing source to the place you want to measure the current and your waveform displays don't need to be changed. You can also capture the data to a file for post processing and because the device name remains the same, you don't have to change anything in whatever tool you are using to do the post processing.
mike__MecE
Joined Feb 20, 2022
69
Ok that makes sense. Thanks
