This one should have a sticky !!!In terms of the common AC supply they are considered to be at the same potential, one main distinction is that neutral is considered a current carrying conductor whereas the ground should never intentionally be used as as such.
Or the expression 'Swinging the Lead' takes on another connotation.But where do you connect to ground on a Navy ship.
Pot plant, perhaps?
For the antennas, the best ground plane, is the water.Well, thats all very well for the aircraft ground, But where do you connect to ground on a Navy ship.
Pot plant, perhaps?
