ebeowulf17
- Joined Aug 12, 2014
- 3,307
I was wondering about that too. If the 50Hz noise only needs to be blocked in order to protect the rest of the system, that's one thing, but if you need to filter it in such a way that you can still detect the smaller signal, that would be a daunting task!With a signal of up to 20 Hz and a 10 times higher amplitude noise of 50 Hz, it sounds like a difficult task.
Honestly, the more I think about this problem, the less certain I am that I actually understand the user requirements. In addition to my earlier question about AC and negative voltages, I'm still not clear on whether or not analog voltage measurements are critical here - is the signal just a pulse train? Do we only need to capture the frequency of the signal, or an analog voltage measurement, both at the same time, or maybe a complete capture of the full waveform?
If we're just protecting an input, some of those details may not matter, but if we want to read the signal through the noise, we'll need to understand the critical parameters of the signal much better!
