https://www.sunpower-uk.com/glossary/what-is-equivalent-series-resistance-esr/Is there a simple formula for ESR
What result do you get from a measurement using the LCR Pro1 plus?Hi,
Recently I bought CapXon LZ low impedance capacitors to replace old capacitors. I was a little surprised at the very low ESR.
For example, 1500uF 25v-0.004Ohm.
So should it really be?
There are no my capacitors in this catalog.This version of the catalog also shows the LZ series on page 188 and following, and this catalog shows the max ESR at 100 kHz. However, the 25 volt 1000 uF cap is shown as having a max ESR of 20 mohm, whereas the data found by paulktreg shows a max ESR of 18 mohm for that cap, but both data sheets show the same ripple rating of 2180 mA.
The URL was somehow corrupted; I edited it and it should work now.There are no my capacitors in this catalog.
At that time, I did not have the LCR Pro1 Plus. I sold this meter.What result do you get from a measurement using the LCR Pro1 plus?
by Aaron Carman
by Jake Hertz
by Aaron Carman
