What is a Tridirectional Bus?
MikeyChris
Joined Mar 10, 2018
31
Recently I have been looking over some very old TTL data, and found a term that is new to me - a TRIdirectional Bus. I was unable to find a definition (one of the few times Google has failed me). From what I can gather, the term is not a misprint (it appears in too many datasheet specs) and is NOT someone's idea of what a TRI state output may be (I have found specs that suggest devices made for TRIdirectional busses can also be Tristate devices). So, I ask you - what is a TRIdirectional bus? Thanx.
JWHassler
Joined Sep 25, 2013
308
Could be an attempt to skate around NatSemi(?)'s trademark "Tri-State"
danadak
Joined Mar 10, 2018
4,057
Is the book referring to TriState Buss, bi directional when active, floating
HiZ when in TriState ?
Regards, Dana.
kubeek
Joined Sep 20, 2005
5,796
The only reference I found is a SN74LS442 chip, which acts as a sort of bridge that enables three chips to communicate with each other. Not very usual or useful IMO.
OBW0549
Joined Mar 2, 2015
3,565
Do you have a link to a datasheet? I couldn't find one...
Try this link for an HCMOS version of the part. It is described as a "quad Tridirectional Bus Transceiver" and has three 4-bit ports. A two-bit input selection code selects which of the ports is to be used as an input, and three output-enable pins select which port or ports the selected input will be transferred to.
The chip itself is "tridirectional" only in that it interconnect its three ports in any input/output configuration; as for a "tridirectional bus" per se, I don't believe there is any such thing.
MikeyChris
Joined Mar 10, 2018
31
Never heard of it. Can you post a reference so we can see the context in which it's being used?
The context was merely an attribute listed in a few datasheets, with no further comments. I was researching some old parts in my stash when I saw these references in several old online databooks (which, of course, I can't find again).
MikeyChris
Joined Mar 10, 2018
31
Thanx for that tip! At least that is more info than I had found so far. So it sounds like these things are similar to ganged data selectors maybe, with open collector outputs available??? Thanx again!
MikeyChris
Joined Mar 10, 2018
31
It is now becoming clearer and clearer.... Thanx!
