Need to know the application.What disadvatage can I get to replace arduino mega 2560 with arduino due or raspberry pico
Smart home system, like door lock system, automatuc water faucet, smart electric system (relay system), ...Need to know the application.
For smart gardening with PIR sensor, soil humidity sensor, raindrop sensor, water level sensor, water solenoid, LDR sensor, and IR distance sensor, it is good idea ?, and what disadvantage can I get ?Need to know the application.
The Pi Pico is an MCU and can be programmed in the Arduino IDE. It's not an SBC like the RPi.The two Arduinos have the same design / debug environment, probably with no OS
the Pi is very different, probably with a Linux flavour OS.
Pi is more capable, Arduino is easier to learn,
Arduino has more easier to access IO capability than the Pi ,
The 2560 has 5v Io capable pins, the Pi is 3v3 capable IO
