See post #27.In a word, pawn promotion.
Hi,This seems very promising, after all you can get 25mm vinyl disks with NFC chips very cheap, and the size will fit the base of a nicely sized chess piece.
But there are 64 squares on the chess board, that would mean 64 sensors which is not a trivial undertaking. A camera seems to make the most sense when the 64 distinct locations is considered.
Yes ok very nice.See post #27.
Im not sure if anyone mentioned this yet but unless there is a different reason for identifying the pieces i would say you dont have to.I am making a chess board with integrated AI for a year 12 school project and I am not sure what kind of components I will need to use to be able to sense what pieces are where at the start of each turn. I was thinking of using RFID but the range is too long I also thought about using smart card chips, but I couldn't find a source for just the identification chips in them.
Any suggestions for what kind of components to use would help or any source for the ID chips.
Yeah i was wondering that too, good point. The range would have to be limited.He rejected RFID in the original post.
It sounds like he could not single one square with a reader.
Why not indeed? Please see post #29. You can get black and white jack sockets.Why not mimic a pocket/travelling chess set where the pieces have pegs on the bottom which are pushed through holes in the board. Use stereo jacks as the pins into stereo sockets. I'd need to work out the detail, but permuations of resistors and diodes between the three contacts should suffice to distinguish the identity of the pieces. Software to cross check if an extracted pieces ends up in a legitimate square etc...
Oops, sorry didn't spot that, skipped through the posts too quickly, my bad.Why not indeed? Please see post #29
I'll elaborate my idea now that I know I have a supporter!Oops, sorry didn't spot that, skipped through the posts too quickly, my bad.
Added advantage, easy to move the game without pieces going everywhere...
You just gave me an idea.Could you have a jack socket in each square, and move the piece by unplugging it from where it was and plugging it back in where it has moved to?
If so the piece could be identified by a resistance between the jack plug terminals.
All that would be required is 64 A/D inputs, or perhaps a way of multiplexing them on to 8 A/D inputs by using 8 line drivers.
The price should not exceed $300AUD overall, some requirements are that it includes a mechanical system (moving part not controlled by the player), an electronic system (raspberry pi/Arduino) and a closed loop system. I don't have much experience with coding and such but I do have an eager family that really wants to do it for me.I am making a chess board with integrated AI for a year 12 school project and I am not sure what components I will need to use to sense what pieces are where at the start of each turn. I was thinking of using RFID but the range is too long I also thought about using smart card chips, but I couldn't find a source for just the identification chips.
Year 12 project? Age 17? Lower sixth form?The price should not exceed $300AUD overall, some requirements are that it includes a mechanical system (moving part not controlled by the player), an electronic system (raspberry pi/Arduino) and a closed loop system. I don't have much experience with coding and such but I do have an eager family that really wants to do it for me.
I was thinking along the same line.You just gave me an idea.
Instead of jack sockets, use magnetic connectors. The board would have the connector and the piece the connector, and the piece holds the necessary electronics to be distinguished from other pieces. A player picks up a piece, places it down, no problem, no jack, no real connector. The connection is made when the two magnetic connectors make contact with each other. Would probably have to be two pole, so two contacts for each square and piece.
If rotational orientation is a problem, use circular magnetic connectors. That would be one inside the other, one circular terminal inside the other. May still want to have some sort of mechanical piece positioner such as a mild cone shape that the piece fits into.
Circular contacts may be hard to find, so a physical means to orient the piece correctly would allow simpler shapes (rectangular) to be used.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
