Thanks ken I will bench test it tommo at my end ...but when u tested it what was the time delay coming during turn ON
with water detected output goes high .If you can find an "automotive rated", logic-level, P-channel MOSFET it might work. The turn-on will likely be less predictable that the comparator. The turn-on will probably be a gradual, not complete OFF to complete ON, and may be flickery with any motion. But it's worth a try.
Google: p ch mosfet automotive logic level
Also, did you want a high or low output on this one when water is detected? I was assuming High. N-Chanel if you want Low.
Ken
