As you saw in the data sheet: "The LM211 is identical to the LM111, except that its performance is specified over a −25˚C to +85˚C temperature range instead of −55˚C to +125˚C. The LM311 has a temperature range of 0˚C to +70˚C."Dear KMoffett,
Kindly let me know what is the main difference in functionality of LM111 and LM211 what I figured out from datasheet is the difference in working temperature range .Apart from temp range effect is there any other difference between LM111 and Lm211 in terms of electrical characteristic .
"Op-amp [as a] voltage comparator" :http://en.wikipedia.org/wiki/Comparator#Op-amp_voltage_comparatorCan you please explain in detail why this OpAMP NCV2904 as a comparator is not a good idea to implement .What all failures can be associated with the same .
A surface mount capacitor would be less prone to vibration failure than a radial or axial lead electrolytic.Dear KMoffett,
I am already using this tantalum capacitor in this project by using this capacitor is there still a chance of capacitor to get affected by vibration test?
R1 will have to take the power dissipation for the clamping Zener in case of a "load dump" or spike. Since a little bigger might help and the cost is insignificant (unless you are going to make thousands of these) I suggested it.Also let me know what all can be the reasons for failure of R1 and what is the purpose of increasing the wattage to 1/2W .
