my plan is just to monitor the the line after the pump so i will be able to pick up a failed in the pump or a loss in performance from the pump but come to think about it you may be right even through the line is under pressure the cant be a very high flow rate. thus far this is the only sensor ive found that can handle methanol http://za.rs-online.com/web/p/flow-...47B377D247C5E5C647B31307D2426706F3D313426736E. but perhaps a pressure switch might be better suited to my applicationSome of the rules around here are a bit squishy, as the mods try to retain some flexibility and allow a free exchange while still being safe. The automotive rule is not squishy at all. But I'm no mod, so maybe they see this case differently. Maybe a race car is not an "auto".
I think I understand that you're trying to avoid a loss of flow of the water/methanol since it is providing cooling and slows detonation, similar to an octane boost.
Were you thinking of protecting each cylinder individually? I'm trying to understand the flow rate. I think it's much lower than most industrial flow detectors will be made for. I was thinking detecting a loss of pressure would be easier, but that would not protect against a situation where it plugs, and you still have pressure but no flow.
