I'm looking for a pspice model for a 7805 voltage regulator. The problem is that I 'm having a hard time trying to find it. Does anyone know where I can find this model?
Here is a zip file for LTspice that has the subcircuits and the .asy files for LM7805, 7812, and 7815. I also threw in LM317. You probably can't use the .asy files, but you might be able to use the .lib file for Pspice.I'm looking for a pspice model for a 7805 voltage regulator. The problem is that I 'm having a hard time trying to find it. Does anyone know where I can find this model?
Nope, sorry.Hi, Ron H.
Do you have Pspice models for MIC502 (fan-management IC) and SS495A (Hall-effect sensor). I really need it to do a circuit simulation.
Thanks in advance.
zip files didn't work, can you helpHere is a zip file for LTspice that has the subcircuits and the .asy files for LM7805, 7812, and 7815. I also threw in LM317. You probably can't use the .asy files, but you might be able to use the .lib file for Pspice.
Someone who uses LTspice (there are a lot of members here who do) might be able to use them.
I didn't test these after I zipped them, so if there are any problems, let me know.
This thread is 9 years old, and @Ron H was last seen more than 5 years ago. Can you elaborate on what does not work about the .zip files?zip files didn't work, can you help
I added the zip to my PSpice Library but it wont popout. How can I make it appear? I only get the LM324. I tried doing "edit" > and changing the reference model but I'm not sure how to verify it works.Here is a zip file for LTspice that has the subcircuits and the .asy files for LM7805, 7812, and 7815. I also threw in LM317. You probably can't use the .asy files, but you might be able to use the .lib file for Pspice.
