I'm sorry to have to say that this is not quite right. The example you were originally given was a good clear one, but your generalisation of it is at best over-simplified. It can only apply to very simple DC circuits, fed by positive DC supplies referenced to earth. These are common in elementary circuit theory problems, but other arrangements exist.Exactly - great explanation.
The voltage at the "input" of the resistor is always higher than the voltage at the "output" of the resistor, with respect to ground. The voltage was reduced (or indeed, dropped), because of the resistor.
And this is why I'll never become a school teacher. I'll remove my original entry.I'm sorry to have to say that this is not quite right. The example you were originally given was a good clear one, but your generalisation of it is at best over-simplified. It can only apply to very simple DC circuits, fed by positive DC supplies referenced to earth. These are common in elementary circuit theory problems, but other arrangements exist.
You might start to see the problem better if you think about the following issues.
Depending on whether the supply or supplies feeding a resistor is/are positive or negative or AC, and on other voltages that may be present in a complex circuit, the voltage at either end of a particular resistor may be "higher" with respect to ground. This does not necessarily tie in with which end of the resistor might be considered the "input" or "output".
- Does "higher" mean having a more positive value, or a greater absolute value, neglecting the sign?
- What happens with a negative supply, or if there is more than one supply, some of which may be negative?
- What happens in an AC circuit? (Voltage drops also occur with AC: for example the filament lamps in old-fashioned sets of Christmas tree lights are often wired in series.)
Too bad. Your original explanation was a good one for DC.And this is why I'll never become a school teacher. I'll remove my original entry.
That is not quite what I meant: the reference to AC was an afterthought, which on reflection might have better not been made to avoid confusing matters. What I was really objecting to was the statement about the voltages referenced to ground.Too bad. Your original explanation was a good one for DC.
What Adjuster is referring to is a more generalized one to take into account both DC and AC. I don't think his concept is any better than yours.
It may be better to say the end of the resistor receiving a positive conventional current flow will be at a more positive potential than will the other end. These voltages may or may not bear a defined relationship to ground.The voltage at the "input" of the resistor is always higher than the voltage at the "output" of the resistor, with respect to ground.
@tommydyhr: Don't worry about it. I never have been and never will be a teacher either, I'm just a sick old man sitting at home making pedantic little points while I wait for the Grim Reaper. I certainly cannot speak Danish, whereas you clearly have very good English.And this is why I'll never become a school teacher. I'll remove my original entry.
To your point though: "Does "higher" mean having a more positive value, or a greater absolute value, neglecting the sign?". My professor has always taught me that a higher voltage is always considered with respect to the common reference, which would mean that a higher voltage always corresponds to a higher numerical value. Ie. +100V is, naturally, a higher voltage than -50V, because |+100| > |-50|.
Perhaps you could provide a link to that, I fear my efforts may merely have muddied the waters.I attempted to clear up the confusion of "voltage at" and "voltage drop" some months ago for another beginner. I believe the discourse was a successful one.
A voltage measurement will always by definition be a "voltage drop". It is the potential difference measured between two points. This is independent of the amplitude and direction on any implied current.
When we use the expression "voltage" or "voltage at" we generally accept this to mean with reference to EARTH potential.
Yes, that is a very good experiment which we should expect a beginner to encounter.But now the student thinks, OK, I shall ground the black probe, and then I shall be able to measure the potentials at each terminal (with a real meter, not a perfect thought-experiment one).
He or she does so, and taking the difference of the two potentials to be the battery voltage, concludes that the battery is completely dead.
Why may this be wrong? (This is a beginners' question: preferably to be left for a while for beginners to think about it.)
That definition leaves out the part bout "The power lost with that voltage drop is dissipated by heat".I do get all of the points that's been made in this thread, but I doubt that I'd ever be able to explain them to anyone who doesn't have at least some kind of electrical background.
The more "basic" a subject is, the easier it is to confuse people, by being either too thorough, or simply just overcomplicating things.
I'll just stick to the, quite precise, definition found at answers.com:
(′vōl·tij ′dräp)
(electricity) The voltage developed across a component or conductor by the flow of current through the resistance or impedance of that component or conductor.
MrChips;430264 When we use the expression "voltage" or "voltage at" we generally accept this to mean with reference to EARTH potential.[/QUOTE said:So there cannot be any voltage on an airplane??? We had a drawing on the wall in the avionics shop at Midway that showed an airplane towing a bucket of dirt with a "Ground" wire going to it. The verbiage on the drawing said, "What is ground?"
by Robert Keim
