Hey Guys!
I've just started with electronics and want to make an analogue soil moisture sensor (with Arduino).
When I looked online for an explanation of the working, every site said that it works as a voltage divider.
These are my questions:
1. What exactly is a voltage divider? How does it work (for a beginner) ?
2. The tutorial said that a wire has to be connected from the Vcc to an analogue pin on the Arduino for the readings.
But how can a wire from the Vcc send analogue signals about the soil's resistance? Doesn't it just supply power?
3. The tutorial mentioned a capacitor between the Ground and the signal wire for filtering noise.
What is this noise? How can the capacitor filter it? Why does it need to be filtered?
I've attached an image of a part of the tutorial for reference.
Thanks a lot and apologies for my silly questions (couldn't find a satisfying explanation elsewhere) .
