Voltage Comparator on Automotive application help
antoniogamu
Joined Oct 10, 2017
I am working on a project on my car to activate/deactivate the Vehicle Cylindres Management system (VCM) based on the engine temperature. For this I need to monitor the engine coolant temperature sensor and then drive a relay based on the sensor voltage reading to anable or bypass a 100 ohm resistor (Rx). I am using a simple comparator circuit (with hysteresis feedback resistor) U1 = LM324 (see schematic attached) when I tested this circuit on my home garage using a dual power supply and a potentiometer to simulate the temp sensor output, the circuit worked as expected including the hysteresis. But when I connected the circuit on my car engine and run a test the comparator output oscillates a lot when it is getting close to the Vref, also I noticed that the hysteresis window doesn't work as the relay open and close almost at the same Vin (only 2-3 mV) difference when the hysteresis should be at ~ 40 mV.
Vref is coming from a voltage divider using a 10K pot to have Vref = 0.465 V as mentioned the hysterisis supposed to be ~ 40 mV, T1 is a 2N2222 and D is a 1N4007.
Some other observations that might help to get your advise are: The Vcc is the car battery and it fluctuates from 12.0 to ~ 13.5 V (depending on the engine load and operating conditions), the temp sensor voltage changes in very small intervals of 1 mV, during either ramp condition (up or down) the sensor output varies 1mV up/down but it follow the ramp trend. When Vin gets close to the Vref i can hear the relay cycling for about 2-3 seconds before it moves to the right state based on the Vin.Comparator.jpg
Some of the modifications that think can help are: using a real comparator such as LM239 and adding a capacitor ~ 0.1 uF between Vcc and GND.
Any advise will be greatly appreciated.
Thanks,
Antonio
wayneh
Joined Sep 9, 2010
18,105
Those are both good ideas. Don't forget the comparator output is open collector, so it needs a pull-up resistor to go high.
Note that your voltage reference at the comparator is proportional to the raw vehicle 12V, which varies and is noisy. I recommend putting a voltage regulator there to isolate the reference voltage.
