verilog, verilogger, file with 'v' extension
PG1995
Joined Apr 15, 2011
832
Hi :)
Yesterday, I borrowed a book from someone and the book had a companion CD. Out of curiosity, I checked out the CD's contents and also read the introduction pages of the book. The book said the CD contained Verilog HDL files for some of the examples in the book with the software Verilogger Pro, Waveform Viewer, etc.
The files had 'v' extension which I wasn't able to open even after installing the Verilogger Pro. But I was successful in opening the file with the Notepad. The code below had the contents of one of the files.
After little searching on the net I came to know that Verilog is hardware description language (HDL) and Verilogger Pro is a simulator. Does it mean that if a write a certain code then the simulator can tell me how that code will be implemented like which component you will need etc.? Is HDL primarily used for digital logic?
How do I open that 'v' extension file?
Please help me with the queries above. Thank you very much.
Regards
PG
jwilk13
Joined Jun 15, 2011
228
The one time I've seen Verilog HDL used was with an Altera FPGA, using the software Quartus II. I've never used or heard of Verilogger Pro, so I can't speak to that. Try Googling it and see what you come up with.
Georacer
Joined Nov 25, 2009
5,182
There are two types of software concerning HDL: compilers and simulators.
Compilers will construct a circuit based on your description. Usually they can be quite imaginative, if the description is abstract.
Simulators will provide you the output of your circuit given an input, without worrying about the circuit's contents and their presentation.
Some suites combine them both.
HDL is mainly used for the design of VLSI systems, were modular development and pre-production testing is a must.
rtay
Joined Jul 27, 2011
10
Like it was already described, verilog is a language that allows you to describe how you would like your hardware to behave. For example, you might specify the number of inputs to your hardware, the digital operation you would like to perform on the two inputs and produce an output out of the operation. In that manner, you can build multiple 'modules' that use digital logic. You put that in a .v file. The compiler looks at your descriptions in your .v and produces the digital devices that will carry out the operation you specified.
The simulator allows you to see if the compiler has translated your description properly. So for example using modelsim, you can write another .v test file that describes the values of your inputs at certain times. The simulator takes your test file that contains descriptions of your inputs and applies them to your compiled original .v file and shows you the output you should expect out of your modules and hardware.
Another tool in the hardware language is synthesizer. This performs the physical planning and implementation of your modules on your final hardware. Given a certain hardware that the synthesizer recognizes, it will allocate your .v code to what is physically available on the hardware. Finally once you are satisfied with the results of your simulator, you download your hardware description to your actual hardware using a programmer.
PG1995
Joined Apr 15, 2011
832
Thank you, everyone, for the replies.
I have MultiSim and Circuit Wizard programs. They both let you use gates in electric circuits. But I don't think they do what I describe below. Do they?
I want a program in which I can drag-and-drop the gates etc. and then simply describe the inputs to see what the output should be.
For example, suppose I have created the following circuit after dragging-and-dropping the NAND gates, then I state what the inputs would be to A, B, and C, and then the program tells me the output at Q.
rtay
Joined Jul 27, 2011
10
Hi PG1995,
I haven't used MultiSim and Circuit Wizard but here is how I think you can use verilog and programs associated with it to do what you described. Altera's Quartus, in addition to doing the verilog stuff, also allows you to draw block diagrams with the pick and drop method. You don't have to use verilog for this. You then compile your block diagram and tell the compiler that you will be using ModelSim to simulate it. So it compiles it and produces a corresponding VHDL/Verilog file from your block diagram that you can use in Modelsim. Now here is where I think you may need a description language. You write a test bench with a description of your inputs and timing conditions and compile that with your verilog file that was produced by the compiler from the block diagram. You then simulate your module and see the outputs in waveform.
If there is a method of simulating your block diagram without using a text based test bench, I'm not familiar without it and I hope somebody else chimes in about it. Quartus used to let you simulate your modules directly without writing a test bench (the design is loaded with a list of inputs/outputs and other variables after compiling and inputs can be changed by right-clicking and assigning values to them). I don't know what happened to that. Maybe it is still out there somewhere in some program. Anyway, see the attached pictures for an illustration of this post.
And here is a tutorial about it:
http://edg.uchicago.edu/software/altera/quartus_tutorial/
PG1995
Joined Apr 15, 2011
832
Thank you very much, rtay.
I have been told that I can also do what I want to in Multisim or Circuit Wizard. I appreciate your help.
My best wishes
PG
PG1995
Joined Apr 15, 2011
832
Hi, again, :)
If we have a mathematical function, say f(x) = y = 2x + x^2, we can graph it with a graphing calculator or with some math program. I'm going to learn some topics which involve Boolean functions and logic gates where gates are represented in terms of Boolean functions. For example, the given Boolean expression AB + A(B+C) + B(B+C) can be implemented using logic gates. Is there some software which I can use to do these things? I can't learn Verilog for this in such short time. In other words, is there some software which I can use to play around with Boolean algebra and logic gates? Thanks for your help and time.
Regards
PG
Georacer
Joined Nov 25, 2009
5,182
Google Boole-Deusto. It's an experimental program that has all of the functions you need to create Boolean expressions plus an elementary circuit wizard.
PG1995
Joined Apr 15, 2011
832
Hi
There is something really wrong with the code of 4-bit four-to-one mux below. I have checked the code of 4-bit two-to-one mux separately and it works okay. It means that the error lies somewhere in the code for four-to-mux. You can see here that output Y3 is "1" when it should be "F", and it's "0" when it should be "A" and so on. Please help me with it. Thanks.
Rich (BB code):
//4-bit 2x1 Mux
module two_to_1_mux(Y,A,B,Sel,En);
input [3:0]A;
input [3:0]B;
input Sel,En;
output [3:0]Y;
reg [3:0]Y;
always @(En or Sel or A or B)
  if(En==1)begin
  if (Sel==0)
  Y <= A;
  else
  Y <= B;
  end
endmodule
Rich (BB code):
//4-bit 4 to 1 mux using 2 to 1 muxs
//we will use the code for 2-to-1 mux given above for instantiation
module four_to_one(Y3,A,B,C,D,Sel,En);
input [3:0]A;
input [3:0]B;
input [3:0]C;
input [3:0]D;
input [1:0]Sel;
input En;
output [3:0]Y3;
two_to_1_mux mux1(Y1,A,B,Sel[0],En);
two_to_1_mux mux2(Y2,C,D,Sel[0],En);
two_to_1_mux mux3(Y3,Y1,Y2,Sel[1],En);
endmodule
//stimulus
module testbench;
  reg [3:0]A;
  reg [3:0]B;
  reg [3:0]C;
  reg [3:0]D;
  reg [1:0]Sel;
  reg En;
  wire [3:0]Y3;
  four_to_one fourMux(Y3,A,B,C,D,Sel,En);
  initial
  begin
  A<=4'b1111;
  B<=4'b1010;
  C<=4'b1100;
  D<=4'b0011;
  En<=1;
  Sel=00;
  #20 Sel=01;
  #20 Sel=10;
  #20 Sel=11;
  #20 $finish;
  end
endmodule
Useful links:
http://wiresharklabs.wordpress.com/2013/03/27/chapter-5-combinational-logic/
Regards
PG
PG1995
Joined Apr 15, 2011
832
Thank you.
I tried to mend the code but it's still not working. Could you please help me with it? Thanks.
Errors:
Rich (BB code):
input [3:0]A;
input [3:0]B;
input [3:0]C;
input [3:0]D;
input [1:0]Sel;
input En;
output [3:0]Y3;
output [3:0]Y1;  //addition
output [3:0]Y2;  //addition
endmodule
//stimulus
module testbench;
  reg [3:0]A;
  reg [3:0]B;
  reg [3:0]C;
  reg [3:0]D;
  reg [1:0]Sel;
  reg En;
  wire [3:0]Y3;
  wire [3:0]Y2;  //addition
  wire [3:0]Y1;  //addition
        initial
            begin
                A<=4'b1111;
                B<=4'b1010;
                C<=4'b1100;
                D<=4'b0011;
                En<=1;
                    Sel=00;
                #20 Sel=01;
                #20 Sel=10;
                #20 Sel=11;
                #20 $finish;
            end
endmodule
PG1995
Joined Apr 15, 2011
832
It's still not working! I declared them as registers. Please help me when you get time. Thanks.
Errors:
Rich (BB code):
input [3:0]A;
input [3:0]B;
input [3:0]C;
input [3:0]D;
input [1:0]Sel;
input En;
output [3:0]Y3;
reg [3:0]Y1;  //addition,
reg [3:0]Y2;  //addition,
two_to_1_mux mux1(Y1,A,B,Sel[0],En); // line 21
two_to_1_mux mux2(Y2,C,D,Sel[0],En); //line 23
endmodule
//stimulus
module testbench;
  reg [3:0]A;
  reg [3:0]B;
  reg [3:0]C;
  reg [3:0]D;
  reg [1:0]Sel;
  reg En;
  wire [3:0]Y3;
        initial
            begin
                A<=4'b1111;
                B<=4'b1010;
                C<=4'b1100;
                D<=4'b0011;
                En<=1;
                    Sel=00;
                #20 Sel=01;
                #20 Sel=10;
                #20 Sel=11;
                #20 $finish;
            end
endmodule
PG1995
Joined Apr 15, 2011
832
Hi again
I have written the following code for a full adder but it gives an error. The error is about line #13 and says that "Lval 'w1' cannot be a net". Could you please help me with it? Thanks.
Rich (BB code):
//full adder
module full_adder(S,C_out,A,B,C_in);
    input A, B, C_in;
    output S, C_out;
    reg S, C_out;
    wire w1;
    always @(A or B or C_in)
        begin
            assign w1 = A^B;   //line #13
            assign S = w1^C_in;
            assign C_out = (w1 & C_in) | (A & B);
        end
endmodule
Brownout
Joined Jan 10, 2012
2,390
You had the opposite issue, eh? Just remember, if a signal is assigned within a procedural block, as in the always@ block in your first example, then declare it as "register" If a signal connects to a sub-module or is assigned as a concurrent assignment (using "assign") then declare is as "wire" BTW, you code created unintended latches (very bad) Look up intended latches in Verilog(VHDL) Try google eg. unintended+latch+verilog
