But how is that possible?
The IC is in the correct place according to the print...
The notch on the IC is right above the notch from the IC socket and right above the notch drawn on the print itself.
And according to the instruction in the manual it's also mounted correctly.
Still, I tried turning it around, in which case te entire kit doesn't do a thing.
So I turned it back and in that case it's still the same going too fast first and then suddenly stopping.
