People on the ebike forum have good success using standard SMPS as dc-dc convertors to run lights and other 12v and 5v accessories. I actually used to sell 36v-72v to 12v converters, but I can't find any that'll run off high voltages.
So I got this 12v 5a smps charger off ebay.
It works, but of course not as expected. It only outputs ~8v. The adjustment pot does nothing, but I assume it won't be too hard to figure this thing out. Something else I'd like to mod (remove really) is the rectifier so that it won't fail pre-maturely.
The output dual op-amp ties into the feedback of the uc3843 through an optocoupler. Since this output has a voltage divider that is the pot, (and since the pot does nothing) I'm going to guess that nothing I do on the output stage will help. So this leaves the uc3843. I attached the data sheets to these devices.
