using a laptop PSU as a dc-dc
auraslip
Joined Oct 17, 2011
12
People on the ebike forum have good success using standard SMPS as dc-dc convertors to run lights and other 12v and 5v accessories. I actually used to sell 36v-72v to 12v converters, but I can't find any that'll run off high voltages.
So I got this 12v 5a smps charger off ebay.
It works, but of course not as expected. It only outputs ~8v. The adjustment pot does nothing, but I assume it won't be too hard to figure this thing out. Something else I'd like to mod (remove really) is the rectifier so that it won't fail pre-maturely.
The output dual op-amp ties into the feedback of the uc3843 through an optocoupler. Since this output has a voltage divider that is the pot, (and since the pot does nothing) I'm going to guess that nothing I do on the output stage will help. So this leaves the uc3843. I attached the data sheets to these devices.
praondevou
Joined Jul 9, 2011
2,942
Apart from making the power supply working again, it's not quite clear what do you want to do with it.
You also didn't attach any datasheets. However, for the UC3843 you don't need to.
Can I assume that you want a DCDC converter that works with 36 to 72V input voltages?
You need to give us more information and you can also start drawing the diagram from the PCB, or the control/feedback part of it and then post it here.
auraslip
Joined Oct 17, 2011
12
Thanks, sorry I forgot to mention what I'm using it for. I need it for a high voltage battery pack - 84v down to 74v
I'll back trace the feedback section in mspaint or something.
praondevou
Joined Jul 9, 2011
2,942
Somehow I doubt that you will get out 5A out of it if it was designed to work on 110AC. Is there something written on it, what is the minimum AC input voltage for full load? At the corresponding DC-bus voltage regulation would not work anymore because the duty cycle is on it's maximum.
I believe that this threshold is more than 74V.
When you get out 8V, what load did you put on it?
auraslip
Joined Oct 17, 2011
12
Not to be contrarian, but later on someone else posted their testing
"12V" DC-DC converter test results
by methods » Tue Sep 09, 2008 4:19 pm
The topic I wanted to post on is closed: Cheap DC-DC converters for over 60v input.
viewtopic.php?f=16&t=2264
I spent a bunch of time making a post so I have got to put it somewhere. . .
TEST: Toshiba Notebook brick
MODEL: ADP-60RH A (V85)
SIZE: 4.5” x 1.5” x 1”
INPUT: 100 – 240V AC
OUTPUT: 15V 4A DC
*note: Most car alternators keep your battery voltage at somewhere around 14.4V or 14.8V so whenever selecting a “12V power supply” always try to shoot for a 15V unit. That will allow you to make more power for less current (smaller package).
**note: Bricks do not need to say “switching power supply” and in fact most don’t. Simply look for units that don’t look like they have a big heavy transformer inside. Nearly any laptop power supply will meet this criteria.
TEST DC INPUT: 100V, 50V, 36V
TEST LOAD: 4ohm 1% resistor (5.3ohms “hot”)
TEST 1) 100V input
No load input voltage: 100V
No load input current: 4ma
No load output voltage: 15.32V
No load output current: 0A
Loaded input voltage: 100V
Loaded input current: 642ma
Loaded output voltage: 14.5V
Loaded output current: 3.533A
Reality check:
Calculated load: 14.5/0.642 = 4.104 ohms (cold)
Actual load: 4ohms
No load input power: 100V * 4ma = 400mw
Loaded input power: 100V * 642ma = 64W
TEST 2) 50V
No load input voltage: 50V
No load input current: 4.5ma
Loaded input voltage: 50V
Loaded input current: 1.423A
No load input power: 50V * 4.5ma = 225mw
Loaded input power: 50V * 1.423A = 71.15W
**note: Output current was not monitored
**note: Load was heating up so resistance ranged from 4ohms to 6ohms
TEST 3) 36V
No load input voltage: 36V
No load input current: 7ma
Loaded input voltage: 36V
Loaded input current: 1.57A
Loaded output voltage: 12.5V
No load input power: 36V * 4.5ma = 162mw
Loaded input power: 36V * 1.57A = 56.52W
Now that I think about it, maybe using a 15v unit would be better. It's far easier to tune one down rather than up.
Maybe it'd be easier just to make my own dc-dc convertor?
praondevou
Joined Jul 9, 2011
2,942
Well, apparently his converter works down to 50VDC.
However, 14.5V on 6Ohms is 35W, not 50W.
You can try it with a 15V unit and if you are lucky it will work down to 74V...
tom66
Joined May 9, 2009
2,595
If you want to change the input range, you're going to need to mod the transformer by rewinding it.
Have you considered building your own supplies? I've seen some NatSemi parts that can work with 100V inputs. For example, this: http://www.national.com/pf/LM/LM5020.html#Overview
Also, these types of supplies aren't much different to a lower input voltage supply. The main difference is getting the SMPS controller to work well on ~330V DC. A resistor, zener and capacitor are used to form a basic supply to bootstrap the IC. Then, when operating the supply voltage is provided through another winding on the transformer. The transformer is key - as the output is higher than a couple volts the controller is switching, but it can't run the transformer at a high enough duty cycle to get the desired output.
At higher voltages a computer power supply may work.
auraslip
Joined Oct 17, 2011
12
Thanks for posting that. I was looking at some of the ICs, but didn't see the 5020.
The application circuit in the date sheet looks decently complicated, but not too bad. It's a lot of work to drive a simple 12v headlight.
I don't really know what to do. I'm contacting the chinese manufacturer about higher voltage dc-dc. The 36v-72v to 12v models are actually pretty cheap in bulk, but it takes 1-2 months. And I want to ride my bike at night NOW :D
I have an older 12v linear wall wart that puts out ~15v on 110va. I'll try that, and maybe I can build a regulator circuit.
duh, I just realized linear wall-warts won't work on dc.
tom66
Joined May 9, 2009
2,595
Maybe a 19V laptop charger would still put out sufficient 12V at a low Vin?
Some have potentiometers on the board to adjust the output so they could be regulated to 12V. If there is no potentiometer, you can add your own.
