windoze killa
- Joined Feb 23, 2006
- 605
Do you mean the solder is failing or is the copper track pealing off the board? If it is the solder failing it is generally a bad technique in soldering but practice makes perfect. Remember flux is a technicians best friend. Although most solder has a flux core it is not enough. Invest in some liquid flux. If your problem is the copper pealing of the board then I suggest you bond everything to the board with epoxy.
