Are there any issues using two SPST relays instead of a DPST relay? I am running a 220 load through the relay and bought the wrong thing. A DPST is more expensive than two SPST so I figured Id just buy another SPST and run each leg through a separate SPST relay. The relay control is 12VDC. I would run these in parallel rather than in series, correct? There wouldn't be any issues with one relay connecting before the other, right?
Thanks for your help.
