TVS diodes clamping Voltage is 57V and if I/P voltage > 57 V then diode would burn ?
Nohi L,
Welcome to AAC.
If the current thru the TVS was not limited in some way it would over heat.
Do you have a burn out TVS problem.?
E
Or blow the fuse.hi L,
Welcome to AAC.
E
A fuse blowing would limit the current???If the current thru the TVS was not limited in some way
It certainly would.A fuse blowing would limit the current???
A fuse in series with a TVS diode is the typical way to protect the TVS diode when it conducts due to over voltage.A fuse blowing would limit the current???
