I can't recall using any scopes that didn't use a 1, 2, 5 sequence.why is a timebase of 800ns weird?
If the resistance of the middle resistor making up the potential divider inside the 555 (which establishes the thresholds for the chip's comparators) were too high by ~20%, that could account for the frequency reduction which the TS is experiencing. Perhaps the batch of ICs is factory rejects.It's just possible that all the parts from this lot have the same mistake
Time to get out the quinta-focalsWould be nice to de-cap one to have a look at the die.
Would be interesting, but "quinta-focals" sounds too complex for this undergraduateTime to get out the quinta-focals
It's an old person's joke. My eyes just are not what they used to be.Would be interesting, but "quinta-focals" sounds too complex for this undergraduate
Makes me worry what kind of focals I would need at your age if I'm struggling to read the text on chips right now.It's an old person's joke. My eyes just are not what they used to be.
So I setup the following circuit which is supposed to produce a 50% duty cycle adjustable frequency 555 timer(https://www.electronics-tutorials.ws/waveforms/555_oscillator.html).I suppose the parts might be useful if you redo the formulas for on time and off time by taking the revised threshold points into account. It's just possible that all the parts from this lot have the same mistake: intentional or otherwise.
You are right. Basically the 120k resistor has to be high enough that it has little effect on the charging, you can see how much it effects it by how much the measured duty cycle differs from 50%. So yeah this is incredibly rough as I didn't account for that in the theoretical frequency, its just to show that the error is related to the frequency, if I were actually going to try use these chips, I'd do much more measurements, and you are right, I should use a proper 50% duty circuit for something like thatWhere did you get that circuit? It doesn't give a 50:50 mark:space squarewave, because C charges through R1 and R2 in parallel and discharges only through R2, with the current through R1 being subtracted from the discharge current.
If R2 is larger than 50k it won't oscillate at all.
It will give a 50:50 mark:space squarewave on a CMOS 555 if you delete R1, and pretty close to 50:50 on a bipolar 555.
Ah nice thanks for the heads up I completely ignored the output impedance, I didn't realise it was that high for a CMOS 555, that will definitely cause some significant error. Guess I'll have to stop trying to cut corners and build a different circuit with a floating output or get some smaller capacitors so I can match the output better.Your capacitor value is too high, the resistor value is too low and the supply voltage is also too low.
The datasheet of the Intersil ICM7555 (it is a Cmos 555 like your TS555) shows that its output resistance with a 5V supply is 2.5V/4.5mA= 556 ohms to pull-up and is 2.5V/30mA= 83 ohms for it to pull-down. That is "typical" and yours could be worse.
I'll have a look at that after building a better circuit.To turn your maths upside down . . . .
Does the calculated time period differ from the observed time period by a constant amount, by any chance?
That calculation tool is also attached, and I inputted my frequency(200kHz), duty cycle(0.58) and capacitor(1nF) values and got this:The formulas (1-7) (duty cycle/frequency for astable multivibrator) do not account for any propagation delay times from the TRIG and THRES inputs to DISCH output. These delay times add directly to the period and overcharge the capacitor which creates differences between calculated and actual values that increase with frequency. In addition, the internal on-state resistance ron (what I think Alec_t was talking about) during discharge adds to RB to provide another source of timing error in the calculation when RB is very low. The equations below provide better agreement with measured values. The formulas Equation 8 represent the actual low and high times when used at higher frequencies because propagation delay and discharge on resistance is added to the formulas. Because the formulas are complex, a calculation tool, TLC555 Design Calculator can be used to calculate the component values.
Yeah just some superficial error. I would guess its because the maximum column would generate the minimum frequency (maybe haven't looked at the equations yet), and the creator just put the frequency they calculated from a certain column in the same column by mistake.Aren't the min amd max frequency the wrong way round in that table?
Thread starter | Similar threads | Forum | Replies | Date |
V | Astable Multivibrator with TLC271 | Homework Help | 9 | |
Pushing TS555 to Mhz region | Digital Design | 18 | ||
TS555 timer failure | Digital Design | 26 | ||
TS555 (cmos) not working properly in NE555 circuit | Digital Design | 17 | ||
TS555 Circuit Question | Digital Design | 17 |
by Duane Benson
by Jake Hertz
by Aaron Carman
by Jake Hertz
