Hello all, I'm new to the forum. I will try to contribute as much as I browse more of your topics, but for now my first post is asking for a little push in the right direction.
I need to detect very small leakage currents, on the scale of 1/4 mA, without the use of a multimeter.
Basically, I want an LED to turn on when it detects a current above 0.5mA. Anything below that, I want the LED to be off.
I made something that somewhat works using a BJT. R2 would be the device that has the leakage current I'm trying to detect. It looks like this...
I realize this is not a very robust solution.
the difference between 1mA and 0.4mA seems to be enough to open and close the gate (base), but the only problem is the leakage current spikes sometimes and turns the LED on which I want to snuff out. I tried a 180uF cap but the spike lasts longer than I thought so it makes the LED flash more gradually.
Can anyone give me some ideas? I was thinking of using a uC, but I dont want to spend time on something that might not work (will it reliably distinguish such small currents?)
I'm looking for a simple elegant solution maybe even a way to change current threshold this circuit responds to.
