I have a treadmill w/ an incline motor that needs a new up/down switch. The motor tests fine. The original control is in panel and is wired to control board. I can plug the wires in manually and make the platform raise and lower.
The motor has one up, one down, and one common (I assume) wire coming out from it. I have located the 2 hot wires (power). The motor is rated 110/120V AC. How would I wire a DPDT momentary off switch. Any help will be greatly appreciated. Thanks.
