TL431 error in LTSpice
eetech00
Joined Jun 8, 2013
4,705
I have downloaded ltspice model of tl431a from link below,but I am getting below error.Attached symbol below.
https://forum.allaboutcircuits.com/threads/tl431-simulation-help-needed-in-lt-spice.171868/
Place the .asy and .lib file in the same folder as the schematic (.asc) file.
Then, place this directive on the schematic:
.inc TL431.lib
or
.inc TL431.mod
so LTspice can find the TL431 subckt.
Place an .inc directive for ONE file only. It doesn't matter which file because they are both the same.
38,520
My suggestion is if you want the TL431 to be available like any other component in LTspice.
eetech00's suggestion requires you to add the .inc command for every circuit where it is used.
eetech00
Joined Jun 8, 2013
4,705
Yes. but you've made a few assumptions and didn't provide complete instructions.
Yes. but at least it will allow the TS to quickly continue with the simulation.
