TIMER to count for 1 second
honeymustard909
Joined Jul 27, 2011
3
Hi there i was wondering if any of you could help me out here . Basically, i need a Timer to count down a time limit which is used to turn off my device after the specified time limit. My pic18f46k20 is running at 1MHz and it is a 16 bit counter . (65536x(1/250KHz) = approx 1 second. I was wondering if this is a correct approach . The period_counter is to increase the second after the timer finish counting from 0-65536 . However to get 1 second , i have to set the period counter to 4000 instead of just 1 . I thought that the timer takes approx 1 second to finish counting.
INTCONbits.TMR0IF = 0; // clear roll-over interrupt flag
T0CON = 0b00000001; // pre scale 1:4
TMR0H = 0x00; // clear timer
TMR0L = 0x00;
T0CONbits.TMR0ON = 1;
void timer (void)
if ( INTCONbits.TMR0IF == 1 )
TMR0H= 0x00;
TMR0L= 0x00;
period_counter++;
if ( period_counter > 4000 ) // 1 second
LATDbits.LATD7 = 1;
period_counter = 0;
counter_second ++;
honeymustard909
Joined Jul 27, 2011
3
Why does it takes 4500 to generate a second ?
void main (void)
//Init the output ports
TRISD = 0b01111111; // RD7 as output
//Init oscillator frequency
// OSCCON = 0b00110110; // to set the frequency to 16MHz
// OSCTUNE = 0b01011111;
// Init Timer
// INTCONbits.TMR0IE = 1; //enable interrupt flag
T0CON = 0b00001000; //counts 16 bits no prescaler use internal oscillator
TMR0H = 0x80; // clear timer
TMR0L = 0x00;
T0CONbits.TMR0ON = 1; // start timer
while (1)
timer();
counting();
seconds();
// minutes();
void timer(void)
if (INTCONbits.TMR0IF == 1)
TMR0L = 0xFF;
TMR0H = 0xFF;
period_counter++;
void counting (void)
if ( period_counter > 4500 ) // 1 second (4000)
LATDbits.LATD7 = 1;
period_counter = 0;
counter_second ++;
void seconds (void)
if (counter_second > 1)
LATDbits.LATD7 =0;
counter_second =0;
counter_minute =0;
counter_hour =0;
