we dont have any cfm type rating. we have a simple, semidesert, and desert type coolers. mine is 4-5 feet tall and 3-3.5 feet wide desert. it has a 60 liter tank at the bottom and we have a small pump motor to take water to the upper tank. this tank has holes at edges on three sides to drop water on the walls stuffed with a special grass. now if the grass is just wwet we get a cool and dry air. if water keeps running there is humidity and cooling is not much. and we desperately need cooling now. its 44 degrees and supposed to rise to 48-49 degrees. so i am trying to just keep the walls wet to avoid humidity. for this there is an adjustable timer I've made.what size is your swamp cooler?
Normally the water feed in the U.S. is from an tapped outside spigot. The water pressure allows the water to fill the bottom of the swamp cooler.
Attached is a manual for a 3000 cfm model.
