Three Phase Rectlifier with PSPICE need help
MikeML
5,444
Where is there an inductor in any rectifier? Post a schematic of the circuit you are trying to analize, or at least the netlist...
MikeML
5,444
When LTSpice makes this sooo easy, why use PSpice?
Note how easy it is to name a node, then display the voltage at a node, display voltage between any two nodes, and the current through any component...
Pellz
Joined Nov 27, 2013
10
thanks :) pspice recommended my supervizor
Pellz
Joined Nov 27, 2013
10
That simulink result was good, i have another task: UL = f(IL) UL = f(diode) how to get it? Now it is function, scheme same.
