thoughts for a latching circuit
nmc240
Joined Mar 12, 2010
21
I have a sensor that gives a signal that varies from 0-4.5V the sensor is powered by 12 volts. The question I have is how do I get the signal to latch and hold at 4.5V once it has reached 4.5V, until there is a power off?
Any help would be appreciated.
Bernard
Joined Aug 7, 2008
5,784
1. Low power SCR, [ 2N5060 ], needs inverting to have a high output.
2. Flip-flop
3 Latching relay with driver
4. Dual input optical coupler
5. ?
KMoffett
Joined Dec 19, 2007
2,918
Some sort of analog, comparator-triggered, sample-and-hold
Maybe a PIC with an ADC input and a DAC (PWM/low pass filter) output.
Ken
nmc240
Joined Mar 12, 2010
21
Sorry for the long time between replies, I was out of town over the weekend. I have looked at all of the ideas and one thing I noticed was that there was no cheap way to do it. Is there a cheap way to do this?
Thanks
nmc240
Joined Mar 12, 2010
21
Yes this is an automotive project. The signal I need to latch goes from 0-4.5V depending on the pressure is applied to the gas pedal.
rjenkins
Joined Nov 6, 2005
1,013
Sorry, the forum policy does not allow projects that could affect vehicle safety & connecting in to the throttle control is a very hazardous thing to do.
nmc240
Joined Mar 12, 2010
21
It actually doesnt attach to the throttle. I used a IR LED and Poximity sensor to measure the distance from the pedal to the floor.
nmc240
Joined Mar 12, 2010
21
Kinda changed directions alittle bit, Just wondering if this looks like a viable option for peak and hold.
Would this make the signal stay at the highest level that it reached until the switch was closed?
