I am trying to predict the approximate temperature that will be generated through a ceramic wire-wound resistor (those little white blocks that are about 10x10x50mm), so that I know if it needs to be enclosed within a case to prevent accidental contact with things (like my fingers), and/or need a fan to assist with cooling.
It is a DC circuit running 12V, and I am trying to achieve a load of around 5W (it is a load ballast for an ATX PSU conversion).
Using the normal V=IR and W=IV calcs, I've worked out that I need roughly 29 ohms to achieve 5W, and will use a 10W rated resistor. A 27 ohm resistor should give around 5.3W.
I figure that by using a couple of resistors in parallel, it would halve the current (and therefore heat generated) in each resistor. A couple of 47 ohm resistors in parallel, would be 23.5 ohms and generate 6.1W, but only a little over 3W per resistor, and therefore be a cooler (safer) solution. Am I correct in my understanding so far?
If everything above is correct, then the last thing I want to know is how much of a temperature rise 3W is likely to create, or how hot these things will get. I found some articles that say to calculate this, I need to know the 'thermal resistance' of the resistors - but I am struggling to find this info, and unfortunately, the suppliers don't have datasheets for them. Do these devices all have a common approximate thermal resistance, or can they vary wildly depending on their source? Is there a general figure I can use to base my calcs on, or will it be a case of 'suck it and see' (though not literally - obviously!!).
Graham
(edit)
If I took this a step further, and used 3 x 100 ohm resistors in parallel, then I'd get around 4.3W in total, but less than 1.5W per resistor (so even cooler?) - and I could get away with using the much cheaper 5W resistors, and buy all three for the same cost as a single 10W resistor...??
Graham
(edit)
