Instead of guessing, what is the current drawn by the motor? Then, check the datasheet. A 2N7000 can handle 350mA of current. If the motor draws more than that, the 2N7000 is not a good choice.also the 2n700 is good choice for 5V
https://create.arduino.cc/projecthub/ejshea/connecting-an-n-channel-mosfet-7e0242
Υes you are correct from generator ( of elvis platfrom give 10 V amplitude in the p[ulse not 5 V ) and then the mosfet is full ONDid you miss Audioguru Agains post?When the MOSFET has 5V on its gate, it is almost turned off. Less than 5V, it is turned off. The MOSFET you are using needs 10V to fully turn on. Hence, you’d be better off with a logic level MOSFET.
https://components101.com/irf540n-pinout-equivalent-datasheethi,
These two PDFs, are Low Vgs options
E
Well you struck lucky with the particular sample of the '520 that you have. If you were designing/building a circuit for someone else it would not be a good choice of MOSFET. Good designs have to take into account the toerances of individual components and allow for 'worst case' scenarios.i watch some video about the mosfet IRF520 and i saw that is not a good choice for logic circuit (like arduino) but work in my expirement
IRLB8721PbF ? View attachment 221591
i think yes the IRLB8721 which is best way to bias it ?The IRLB8721 looks better than the original choice for operation at 4.5V Vgs:
The IRLZ44 is a another choice.
