I cannot count on it. please read this part:...The module takes up to 40vdc input...
"The product is actually pretty good an loosely follows the suggested circuit for the regulator data sheet. The main problem is the use of a 35V cap on the input. With any capacitor, you never, ever exceed the rated voltage. They can and will fail dead short and blow up.
In fact, we normally never use anywhere near the max rated voltage stamped on a capacitor. So with it being 35V rated, MAX recommend input is roughly 30V making the output a safer 28.5 voltts since both caps are rated 35 volts and the input must be about 1.5 volts higher than the output. The best and easiest thing to do is just change the rating to match the actual components used.
Ideally they should have used 50 volt rated caps. Also note that per the suggested circuit in the data sheet, you should have a larger value 680uF VS the current 220uF.
Again, it's not a bad circuit and it works, just don't run it up to the max voltage rating. Hopefully they will change the rating but this review is for those who already bought or are looking and need that high of an input rating."
I mean I'm a bit worry about it although my module has a 50v Cap at input. look:
if you think there is no problem to connect it, then I'm going to connect it to the 30vDC.
In fact it's a soldering iron's tip. look at this:He means thermostat, not thermocouple.
The maximum allowed voltage input to the buck module is 40V. Here is what is proposed:
I would need to know the heater Wattage (or resistance), and the actual current into the buck module to do this more accurately.
Note that with my guess of a 24V, 24Ω, 24W, 1A heater, if you feed it full-wave rectified, unfiltered 24Vrms, the actual power is only 20.4W. This makes sense, because of the two diode drops in the fwb. See the light blue trace. I let LTSpice integrate that waveform to find the 20.4W.
For the buck regulator, I guessed the input current.
The heater resistance is 9Ω practically.
These tips draw 2-2.5A to work. What do you mean "Transformer Va rating"?I have yet to see any mention of heater current and Transformer Va rating?
