Hi all, I brought the MK134 from maplins, I was wandering if theres away of controling the sound in the actual layout, I:E, when a train starts of its sets the MK134 going and as I speed up so does the sound. Can any body help
It might have been easier for us if you had mentioned that this was a Velleman Minikit MK134 "STEAM ENGINE SOUND GENERATOR WITH WHISTLE" :http://www.velleman.eu/products/view/?id=347727Hi all, I brought the MK134 from maplins, I was wandering if theres away of controling the sound in the actual layout, I:E, when a train starts of its sets the MK134 going and as I speed up so does the sound. Can any body help
That sounds like a brilliantly simple idea, and certainly worth trying. The OP is trying to get a train "chuffing" circuit to speed up as a model train is accelerating. The oscillator speeds up as a variable resistor is turned down.If you need a voltage controlled resistor a photo resistor and an led might be used. Not sure if you have enough know how to work out the details ( even assuming a voltage controlled resistor is what you need )
