Munk - to do it with DC, it could be done with a stepper motor driver. A unipolar stepper driver IC is fairly cheap. You would decide the current/amperage you want to use and check one of the 'wire amperage' charts to find out the length you need for that number of amps.
Then make a toroidal ring out of either steel banding(like they use to strap stuff to a skid) or even heavy steel wire, like fence wire. Wrap the ring with electrical tape. Then wind the wire on the ring in four separate coils, covering the ring. Wrap with electrical tape again.
Then make a 555 timer circuit to control the step input of the stepper IC. wire the coils to the stepper IC and power it up.
That's basically what the guy in this video is doing; http://www.youtube.com/watch?v=EPZRXFPU4Mw&NR=1&feature=fvwp
In the lower left corner you can see his controller, looks like he's using three coil pairs instead of two, because of the way he has the coils made. He has them on end pointing at the egg instead of a toroidal coil. That points the magnetic field at the egg instead of covering a larger area like Tesla did. His egg doesn't move as good as the ones using a toroid.
Thatoneguy - most BLDC motor drivers are expecting three Hall effect signals from the inside of the motor to work. Thats why I am suggesting a stepper driver instead of a BLDC driver, to make this simpler.
