tons of people "bother" with that..Laying a blanket of some sort over the outside of the windshield would probably be more effective and wouldn't use any power. But who wants to bother with that?
Thanks for replying,I think the only way to overcome the total power issue is to 1) limit the area that the heater thaws, and 2) control the heater so that the window is not heated anymore than it needs to be, and maybe 3) auto shutoff if a low battery is detected.
(One could argue that anything less than 100% clearing is not safe.) This strategy would require the user to apply the pad in advance, when they stop their car. I don't think that's a good solution. Laying a blanket of some sort over the outside of the windshield would probably be more effective and wouldn't use any power. But who wants to bother with that?
A nichrome wire worries me - without careful control it would apply too much heat in a concentrated spot and risk cracking the glass.
Thanks for your reply and yes we sure love uphill battles lol.One point I noticed was that you intended to place your heating element
"around the periphery of the screen"
You are facing an uphill battle against the heat transfer coefficient of glass by doing that.
I know you Scots like uphill battles but....
many factors at play there.. could be cold enough outside that all you do is generate enough heat to just warm the area a few mm outside of the heater band..The heat transfer into glass is a huge obstacle but assuming that the ice melts where the wire is then would the then sheet of ice slide slowly to meet its end at bottom of the screen?
That would defrost only the perimeter. Is that what you want?im thinking of using nichrome ribbon around the perimeter of the windscreen
That's true. I once read of a unique project to make three legged underwear to extend use from one day to a week.Hey guys, remember the point of school/college projects is as a learning exercise.
You can get at least as many marks by not succeeding in your original objective but producing a good investigation as to why and what would work as you can by simply trotting out a bog standard rote design.
Thanks for reply, and yes valid points the heated washer fluid has been done to a very high standard,Fill your windshield wiper fluid reservoir with salt water, insulate it like a thermos and put a small PID or thermostat controlled immersion heater inside. Then hack the windshield wiper/sprayer system to start spraying & wiping at the the touch of a (bluetooth) button. This way you store energy (heat), and also employ chemical methods of deicing, both of which reduce the demand on the battery when deicing time comes around.
Or find a sleeker, less lossy way to store energy, and a less corrosive chemical means of deicing (glycerol maybe?).
This sounds really interesting if i could make it discreet enough it could prove to be a good solution to the problem.Here's an out-of-the-box idea. Lay a big long bag of hot pad liquid on the dashboard, with a remote controlled trigger. These liquid hot pads contain a supercooled salt solution that release a buttload of heat when triggered. The salt crystallizes and can be recharged repeatedly with heating. I'm a little skeptical that enough of the heat could be transferred to the window, but I do think it would make a dent.
Thanks for replying and i must admit i do use look warm water at present just find it a hassle and if living in a block of flats may be unpractical.Just melt the ice with some of that liquid that is found throughout your country - whisky.
Really, a bucket of warm water does wonders. If you can use the windshield wipers soon enough, the windshield will still be warm enough to prevent re-freezing. My son does this with his car every morning in Pittsburgh.
I have 3 things to say:This method is brilliant in my opinion and i stumbled on it half way through my project http://news.cnet.com/A-high-tech-way-to-defrost/2100-11395_3-6061333.html
thank you kindly for taking the time to reply
