Possibly. I believe the unloaded high output voltage is about 1.5V below Vcc which would make it 3.5V, right at the CD4000 limit. If that's a problem or you want to provide margin, you can add a pull-up resistor at each output, which would raise the high output to 5V.The high output voltage of LM324 is marginal for delivering a logic 1 to CD4000 logic when Vcc=5V.
