I'm new here, I've been researching a specific old switching power supply, it's from an old audio amplifier.
I think this would be the correct subforum for posting this, since even though it's an amplifier, I've tracked the issue down to the power supply.
This is the schematic for the particular power supply, I've just removed all the upper portion of it, since it's not present on my particular piece of gear.
The supply should be able to provide 42.5v at the output, however currently it kind of "creeps up to" that voltage, only if i leave the output floating. On any kind of load it starts to go down. In particular what's happening is that I can use the amplifier all the way up to about 60W, when I apply more load (turn the volume up even higher) the voltage goes so low that the protection circuitry of the amp kicks in and shuts it down until the voltage can creep up again to a sufficient level.
From what I understand, Q203 is there to "start" the switching, and Q201 and Q202 are the actual switching transistors, this is such an old design that Q201 and Q202 are 2SC2335, as in, they are not mosfets.
I tried testing most of the components in the board, to see if the meet specifications, all capacitors have the correct capacitance, the electrolytic ones that had high ESR were changed along with the pair if it was required. Resistors were also tested and came up with correct values. And I've changed the 2 switching transistors with NOS pieces, and Q203 for a new KSC1815. However I've seen no changes.
The only thing I find that is "incorrect" is that if I probe Q201 for a frequency (between emitter and collector) I see double what I should be seeing (as in, instead of 45uS I see 22uS).
I'll also leave the explanation of how this circuit is supposed to work that is present on the service manual.
Any kind of help is really appreciated, I'm honestly at a loss for how to proceed here, from what I read in the service manual the frequency is established by the windings in the small transformer (T203), and I also don't see any kind of "feedback", so I wouldn't know where or how to affect the voltage/current that the power supply generates.
Thanks in advance!
Juan
Thanks in advance!
Juan
