Did you already have a look at the wiki:
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Bertus
Bertus
In the (almost) early days, the most common type was based on the blocking oscillator, a second transistor which is controlled by the regulation opto shunts its base.I'm with bountyhunter. Fast, cheap mosfets and IC's to drive them became available. Try making a switching supply with only bipolar transistors, no IC's, and you will see the problem.
There were two types of the electro-mechanical vibrator type, synchronous and non synchronous, the non sync. type provided a AC output for the input to a low voltage to high voltage transformer where the secondary was then rectified.They used an oscillating solenoid core within some cylindrical coils, and a high quality adjustable contact set at the end to make it oscillate and probably to do rectification too, I can't remember the specifics. They were military spec equipment labelled as DC-DC converters.
So you don't even need semiconductors or vacuum tubes to make a SMPS!
