smithsaiden
- Joined Jul 5, 2013
- 1
Hi, if you are looking for surge protectors, Powerworx is the right one..it help to protect your sensitive electronics from damaging that occurs due to harmful spikes and surges.
Nonsense.A typically destructive surge is hundreds of thousands of joules. Grossly undersized (and expensive) protectors are maybe hundreds of joules. Undersized to be one shot devices. If grossly undersized and fails, then naive consumers will recommend it and buy more.
Nonsense.A surge, too tiny to overwhelm protection already inside appliances, may damage a protector.
The cheap crap westom buys might. Buy from a major manufacturer.So protector circuits must disconnect as fast as possible.
The IEEE surge guide explains the protected load can be connected across the MOVs, and be disconnected with them if they overheat, or can be connected across the incoming wires. If connected across the MOVs the protected load is not exposed if MOVs fail. (Connecting this way is one reason some manufacturers can have protected equipment warranties.)Leaving a surge still connected to an appliance.
As the link from GopherT makes clear, UL/ULC 1449 has required disconnects for overheating MOVs for over 15 years.Sometimes a thermal fuse does not disconnect fast enough. Wires do not burn. Instead the MOV causes a fire.
Nonsense.Even a power strip protector needs protection provided by the other device - with a same name.
Service panel protectors are a real good idea.The other 'whole house' solution remains functional even after a direct lightning strike. Protects everything inside the building. Protects from all types of surges.
