No. Your oscilloscope is showing about 50ns ringing.Is this an inherent characteristic of the device and we need to use a capacitor to "filter" it out or what? It is just a 50% duty cycle, timer drive GPIO pin.
Ahh, thanks. I have one of these that's attached to the board's ground and the GPIO pin:No. Your oscilloscope is showing about 50ns ringing.
Make sure that you use a x10 attenuation probe AND the probe grounding clip is connected to circuit GND.
You mean 10 Megohm.A typical 10x scope probe has 1 MegΩ with 15 pF to Ground.
Where did you connect the probe's ground lead?I then re-attached the probe to the board, leaving everything set at 10X
The probe ground is connected to one of several ground pins on the board, almost next to the signal output pin.Where did you connect the probe's ground lead?
It should be on the circuit ground close to the source of that waveform.
IndeedYou mean 10 Megohm.
It's one of the GPIO pins on the board, this is the board. It's GPIO 11 on port D.I have a question. What is the waveform source and what impedance is the source designed to work into.
Ron
8 inches is way too long.Finally there was a 8 inch piece of wire between the probe ground crocodile clip and the board ground pin, I rearranged that and made it 1 inch (because the crocodile clip shorts against other pins):
I think I underestimated the impact of poor connection leads between device and scope, that seems to be the upshot of all this.
That makes sense, but in this case the generated signal is just 27KHz, surely that's not what you'd call "high frequency"?8 inches is way too long.
If you want to do high frequency probing, here is what we use. That is less than 1 cm from the probe GND to the circuit GND.
No.That makes sense, but in this case the generated signal is just 27KHz, surely that's not what you'd call "high frequency"?
