A traditional IF amp is a fair bit of work, and you have to know where to look for the IF transformers. Whichever way you go will probably end up with 10.7MHz ceramic filters.Hi,Interlects.I am doing a project,It's a Standard FM,IF Amplifier of 10.7MHz resonant frequency,gain of 5odB and bandwith of 250kHz.I would appreciate your contribution in order to make this project a success.Thank you.
But,how do I Identify the IF amplifier stage in the whole FM reciever circuitA traditional IF amp is a fair bit of work, and you have to know where to look for the IF transformers. Whichever way you go will probably end up with 10.7MHz ceramic filters.
Basic amplifier subsystem ICs are getting harder to find - you may end up with a fully integrated FM radio chip and ignore the circuit sections you don't need.
It has 10.7MHz frequency selective filters - that could be IF transformers or ceramic filters.But,how do I Identify the IF amplifier stage in the whole FM reciever circuit
A circuit diagram would be of great help...It has 10.7MHz frequency selective filters - that could be IF transformers or ceramic filters.
Google broken again?A circuit diagram would be of great help...
It was specified that we should use Transistor.A transistorized IF amplifier would be preferred.I Found one but I need help in getting the values of the components.
