They are related to my error of using a 100 nF C6.
There is a correlation between the manual math and the values during the simulation.
The real life is another story. On your picture, you already noticed that the beam intensity was too high ... in the photo. It takes practice to get the beam intensity low when taking pictures.
I'll assume you adjusted the vertical zero references with the scope in the ground position, as you have indicated you were an experienced technician. If you hadn't, it appears the lower reference for Vc is about 5V ... but that's only interpolating the middle of the beam. That certainly would have changed delta Vc.
Are you sure the C6 in the diagram is the same value as the C6 in your real life circuit.
By the way, HHO projects are not normally discussed here. High voltage projects are also frowned upon for safety reasons.
