HELLO EVERYONE
I AM TRYING TO WRITE A PROGRAM FOR PIC18F6520 TO FEED THE DATA IN AD9954 (DDS). I HAVE USED SPI TRANSFER MODE.
WHEN I USE DEBUGGER AS MPLAB SIM AND SEE THE LOGIC ANALYZER OUTPUT FOR SDO PORT AND CLK PORT NOTHING COMES OUT.
PLEASE HELP ME.
HERE IS MY PROGRAM
PLEASE HELP ME.
HERE IS MY PROGRAM
Rich (BB code):
LIST P=18F6520 ;directive to define processor
#include <P18F6520.INC> ;processor specific variable definitions
;Configuration bits
CONFIG OSC = EC
CONFIG OSCS = OFF
CONFIG WDT = OFF
CONFIG LVP = OFF
CONFIG DEBUG = ON
;Variable definitions
; These variables are only needed if low priority interrupts are used.
; More variables may be needed to store other special function registers used
; in the interrupt routines.
CBLOCK 0x060
WREG_TEMP ;variable used for context saving
STATUS_TEMP ;variable used for context saving
BSR_TEMP ;variable used for context saving
ENDC
CBLOCK 0x000
EXAMPLE ;example of a variable in access RAM
ENDC
;EEPROM data
; Data to be programmed into the Data EEPROM is defined here
ORG 0xf00000
DE "Test Data",0,1,2,3,4,5
;Reset vector
; This code will start executing when a reset occurs.
ORG 0x0000
goto Main ;go to start of main code
;Start of main program
Main:
X EQU 0X07
clrf PIR1
MOVLW 0X08
MOVWF PIE1
MOVLW 0X10
MOVWF TRISC
MOVLW 0X00
MOVWF SSPSTAT
MOVLW 0X20
MOVWF SSPCON1
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x22
movwf SSPBUF
call CHECK
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x01
movwf SSPBUF
CALL CHECK
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x00
movwf SSPBUF
call CHECK
movlw 0x04
movwf SSPBUF
call CHECK
movlw 0x33
movwf SSPBUF
call CHECK
movlw 0x33
movwf SSPBUF
call CHECK
movlw 0x33
movwf SSPBUF
call CHECK
movlw 0x33
movwf SSPBUF
call CHECK
CALL DELAY1
BSF PORTC,7
CALL DELAY1
BCF PORTC,7
CALL DELAY1
FIN
GOTO FIN
;*******************SPI output subroutine***********************
CHECK
BTFSS PIR1,3
BRA CHECK
BCF PIR1,3
RETURN
;*******************DELAY subroutine***********************
DELAY1
MOVLW D'05'
MOVWF X
DELAY2
DECFSZ X,F
BRA DELAY2
RETURN
;---------------------------------------------s
;End of program
END
