Few months ago, I got some samples of a two-axis accelerometer, which has linear outputs of 1V per g.
I want to feed the output of one axis to an opamp connected like integrator with a low time constant. I am not too sure, but the output of the integrator should be proportional to actual speed.
Do you think it would be possible to create a speedmeter like this?
problems that probably will occur:
1) need of reseting to zero every time the motion stops.
2) problem with centrifugal force when the meter is not exactly in axis with the motion
