MaxHeadRoom
- Joined Jul 18, 2013
- 28,700
Me neither, the M340 has input modules that are negative or positive logic capable, if I were implementing a system such as this, I would spec in the most suitable instead of making it hard with external logic.I just haven't figured out why this needs both 5V and 24V when the sensor will work with either of the voltages.
If you already have the card you intend to use and the logic is opposite, or not swapable, then you may have to place a bipolar transistor to invert it, but the 5v should not be necessary?
Max.
